The Fish
Discussion in 'Forced Induction Tech (Members Only)' started by kc95sc400, Oct 4, 2007.
  1. kc95sc400
    kc95sc400 New Member
    May 26, 2007
    524
    Toyota Tech
    Charlotte, NC
    More awesomeness!
    KC
  2. kc95sc400
    May 26, 2007
    524
    Toyota Tech
    Charlotte, NC
    I'll check it out. Currently, the car stumbles a bit between shifts with heavy throttle. I think the compressor surge may be the cause. Without the IC, I had a lot less surge and I can't recall having any shifting issues at all.
    I am still planning on keeping the current setup but trying it without the IC to see what happens.
    KC
  3. kc95sc400
    May 26, 2007
    524
    Toyota Tech
    Charlotte, NC
    Look at picture #15 on post 12. The area where the power distribution block is sitting is where it needs "modded". Like I said, it's a fairly significant amount of bashing that needs to be done.
    Also, the fuse box needs to be MUCH furthur over than in that pic. The fuse box has been and still is one of my worst enemies though this whole thing.
    KC
  4. lexplay
    lexplay New Member
    Jun 26, 2007
    117
    hitech (parts suplier)
    perth (currambine)
    kc are the wire's too short to move the fuse box any where or is thier just no where else for it to go? i can see it getting in the way too.
  5. kc95sc400
    May 26, 2007
    524
    Toyota Tech
    Charlotte, NC
    The wires are not too short to turn the box and shove it over as much as possible. It's just a big PITA. It's really not a good thing to do to any fuse box. Ideally, it should be relocated. I don't know where to though. This would of course require extensive wiring.
    I haven't really looked into it, but it may be possible to use a smaller fuse box. Aftermarket or OEM out of another Toyota. It may also be possible to custom make something. Even if it's just a small plastic box.
    KC
  6. lexplay
    lexplay New Member
    Jun 26, 2007
    117
    perth (currambine)
    gues ill find out shortly. Cause my cars a daily driver as well first thing im going to do is remove the original fan and put the electric fans on, move the battery to the boot, did u run a posative and a negative battery cable to the back? plus try fidle with that fuse box, im sure theirs something we can do with it.
  7. RedPhoenix
    RedPhoenix New Member
    Nov 14, 2006
    512
    Boat
    Palm Harbor, FL
    you dont need to run a negative to the back. just ground out the battery to the chasis somehow
  8. Lextreme
    Lextreme Just call me "Lex"
    Mar 6, 2003
    12,051
    Professional
    City of Halos
    Home Page:
    When u relocate the battery to the trunk. Make sure you solder the connection for good conductivity.
  9. kc95sc400
    May 26, 2007
    524
    Toyota Tech
    Charlotte, NC
    Hey guys,
    I'm having a little drivability problem that started yesterday. I think the gasket I had made to block the EGR might have failed. Or I might have a vac/boost leak.
    IfI manage to figure it out tonight, I'll make some more, longer driving vids on Sunday.
    KC
  10. mshawari1
    mshawari1 Member
    May 7, 2006
    648
    16
    Telecommunication Engineer
    Riyadh
    I agree with you.. That is an important point
  11. stevechumo
    stevechumo Active Member
    Mar 7, 2005
    3,053
    36
    Software analyst
    OC, City of Sunshine
    Just buy a lead melting pot like the one used for casting lead bullet, melt the lead, dip the big wire in there and you're done. :scared:
  12. lexplay
    lexplay New Member
    Jun 26, 2007
    117
    perth (currambine)
    ill prob just run a positive then its just with some cars when iv done it iv had starter motor problems, ran a negative to the block and all sweet.
    i get the oxy out and turn it down low then pump the join full of solder that works good to. should be reseiving the supercharger this week in the mail. cant wait.
  13. kc95sc400
    May 26, 2007
    524
    Toyota Tech
    Charlotte, NC
    Guys,
    Figured out the drivability problem I was having, the MAFTPro was acting up. Reset it and changed the settings some, now all is good.
    Next weekend I'm going to fix my piping and try non IC with the routing shown in the vid.
    Anything in particular you guys want to see in a driving vid? I made a few earlier, but they didn't turn out to great. I need to make a rig for the camera.
    Speedo / tach vids are easy, I can velcro the camera to the steering wheel.
    KC
  14. lexplay
    lexplay New Member
    Jun 26, 2007
    117
    perth (currambine)
    got my superhcarger yesterday thanks to thermactor for his great service would recommend dealing with him again. actually lookiong at it really gets me motorvated but just have to colect a few more things and get a higher paying job lol.
  15. kc95sc400
    May 26, 2007
    524
    Toyota Tech
    Charlotte, NC
    Some new pics.
    Hey guys,
    Some pics of the IC setup that was in place when I made the vids.
  16. kc95sc400
    May 26, 2007
    524
    Toyota Tech
    Charlotte, NC
    Another IC setup pic.
  17. kc95sc400
    May 26, 2007
    524
    Toyota Tech
    Charlotte, NC
    Last IC setup pic.
  18. kc95sc400
    May 26, 2007
    524
    Toyota Tech
    Charlotte, NC
    The new, and hopefully the last setup. This is what I've been doing this weekend. A non IC setup with the pipes ran outside of the engine bay. I haven't quite finished yet, so I don't know what the results are, but I'll post when I do.
  19. kc95sc400
    May 26, 2007
    524
    Toyota Tech
    Charlotte, NC
    Last new setup pic.
    I am very hopefull that this will be the one I will finally keep. I will try and shoot some more vids either tonight or tomorrow, so stay tuned.
    KC
  20. kc95sc400
    May 26, 2007
    524
    Toyota Tech
    Charlotte, NC
    Very cool BTW. I am excited to see how it works out for you.
    KC
