Speed sensor #1 issue mystery
Discussion in 'Drivetrain (Members Only)' started by Gazeebo, Jul 29, 2018.
  1. Gazeebo
    Gazeebo New Member
    Jul 29, 2018
    8
    1
    Gender:
    Male
    Hello everyone:
    I currently have a 90 LS400 with a mysterious code 42 (speed sensor 1). I have replaced the speed sensor, instrument cluster and ECU with no avail. Current symptoms are:
    Code 42 (O/D light blinking)
    Dead speedometer
    Dead Odometer
    Dead trip meter
    Gasoline smell
    Very sluggish performance in gear (not in park or neutral)
    Erratic shifting
    I am seriously thinking it's a wiring issue because car had 2 fuses (GAUGE and CIG) with higher than factory amp rating, I changed them to factory spec fuses and now the battery dies overnight. Any idea what issue this can be? possible wire touching and shorting out?
    Thank you very much for any help everyone.
  2. camo 32v dohc
    camo 32v dohc 1uLux
    Jul 23, 2018
    2
    1
    Gender:
    Male
    fabricator welder
    Brisbane Australia
    Very interested I have same problem my hilux 2wd 5spd man has been my daily driver on and off for almost 2 years now and it has been getting more and more sluggish and just recently been able to not drive it for a couple weeks so I tried to fix this problem, I done the wiring myself it's a early celsior 26/16/22//26 plug ecu I first knoticed that my ecu memory wire was on pin 1 or 26 of 4th plug which ever is incorrect but I corrected that and have been trying to figure out speed signal wire cause I have never had it hooked up and hear that this is possibly where my power issue is fingers crossed if I can find info I need, then last night for the first time since conversion the battery is flat this morning then I see this post any info would be very much valued cause the Ute is needed to move house in two days please anyone.
  3. Gazeebo
    Gazeebo New Member
    Jul 29, 2018
    8
    1
    Gender:
    Male
    I'm calling an electro mechanic tomorrow to try and take it to shop this week. I am completely lost in what the issue may be.
  4. melvinmelvin
    melvinmelvin Member
    Sep 24, 2012
    263
    2
    18
    Not much
    Bangkok
    if your electro mechanic sorts it out
    please be so kind as to come back here and explain problem/solution
  5. camo 32v dohc
    camo 32v dohc 1uLux
    Jul 23, 2018
    2
    1
    Gender:
    Male
    fabricator welder
    Brisbane Australia
    Hope it doesn't take your auto spark to long to sort it, so it doesn't cost u a fortune and gives the others some kind of direction on issues they or I may be having my self I can't let myself let someone other than myself to work on one of my cars or bikes just seen to many rough jobs over the years to take the risk.
  6. Gazeebo
    Gazeebo New Member
    Jul 29, 2018
    8
    1
    Gender:
    Male
    Will do, already got a post in clublexus to also report to if I find something.
  7. Gazeebo
    Gazeebo New Member
    Jul 29, 2018
    8
    1
    Gender:
    Male
    Update:
    Finally got a shop to touch the car. Let's see what they come up with.
  8. Gazeebo
    Gazeebo New Member
    Jul 29, 2018
    8
    1
    Gender:
    Male
    Update:
    Speed sensor was tested with an oscilloscope and no wave signal is being generated. Something somewhere is wrong and he said he could "program" or replicate the signal but cluster wouldn't work. (speedo)
    He told me maybe he is getting wrong info and would want to have another car to test but no one I know has this car. This is gonna be expensive to fix.
