hrforever
- 196
- Melbourne, Australia
Since getting my a/c gassed back up, I've been playing around with the radiator in my conversion as it seemed the motors temps were a little high with the a/c running but as I do not have any reference data to go on I could be over exaggerating the possible problem.
Without the condenser in place, the temps at 100kph sat around 83-85degc. With condenser installed, same speed, temps 84-87degc. With a/c on at 100kph temps jump to 91-93degc. To ensure consistency, I've tried to get all these temps when its around 30degc outside.
Until now, I've always run the electric fan at 93 on/ 88 off but with the a/c on, its possible the fan can come on when doing 100kph and it won't go off.
So question is, are the above temps ok? Should I just change the fan on temp to say 95degc as I know its not going to boil and I just need to get used to seeing different temps as being normal.
For info, aluminium radiator, 2 speed Volvo electric fan, the temp sensors are in standard position and I'm using the Megasquirt to control the fans operation
