Newbie from France
Discussion in 'General Discussion' started by thesnake108, May 14, 2018.
  1. thesnake108
    thesnake108 New Member
    May 14, 2018
    16
    1
    Gender:
    Male
    Hello everyone, I am a newbie from France, I install a 1uzfe in a supra mk3 ;)
    I registered to share with you this experience and have answers to my wiring problems.
    Excuse me in advance for my english (do not hesitate to pick me up) and thanks to those who will try to understand me ;)
  2. cribbj
    Jun 10, 2004
    4,728
    6
    38
    Gender:
    Male
    Consultant
    Houston, TX
    Bienvenue!
    1UZ into Supras are always interesting. Please tell us more - no one will criticise you for your English.
  3. gloverman
    gloverman Well-Known Member
    Oct 15, 2004
    2,724
    63
    48
    mechanic
    Hamilton. New Zealand
    Welcome
    Mk3 supra take a 1uz nicely. I did one just before christmas and have another to do in the next month or so.
  4. thesnake108
    May 14, 2018
    16
    1
    Gender:
    Male
    thanks for your welcome ;)
    27540125_850134271860375_280518650601200820_n.jpg 28684909_863111790562623_6636817104640851986_n.jpg 29542200_874072186133250_8947739882515514444_n.jpg
    Now the step is to wire the 1uz ;)
    At this moment I'm wiring the 1uz, I wire same on this video :
    the engine start succesfully but i have one question : do you know if this wire is ok for run everyday or not ?
  5. gloverman
    Oct 15, 2004
    2,724
    63
    48
    mechanic
    If you read the comments its only for starting on the stand. You should wire the engine correctly when fitting into the vehicle.
  6. thesnake108
    May 14, 2018
    16
    1
    Gender:
    Male
    ok thanks do you have any picture for simplify the wire ? because the car it's only for track it not necessary the air conditionner etc, he going to start with bottom :)
    i have found lot of schemas but the color of the wire does not match...
    i just want to wire the ECU but i don't found a schemas of the ECU for example where it's +12v where it's ground ...
  7. gloverman
    Oct 15, 2004
    2,724
    63
    48
    mechanic
  8. thesnake108
    May 14, 2018
    16
    1
    Gender:
    Male
    thank you for this adress but it's very expansive for just once time :(
    all the swap I search to spend the least possible money because in France the parts are expensive ...
  9. Zuffen
    Jan 21, 2004
    5,295
    12
    38
    Retired Insurer
    Sydney, Australia
    You're paying for some hard earned knowledge that isn't readily available elsewhere.
    The seller is making a living out of 1UZ conversions so he isn't going to give away all his information for free.
  10. thesnake108
    May 14, 2018
    16
    1
    Gender:
    Male
    yes i understand, it's normal ;)
    so yesterday after having put everything originally, I reflected on the schemas about the cabalge 1uzfe that I could find on the internet, after found most of the wire of the ecu (+12, earth etc ...) the engine starts but stops immediately ... I think I'm on the right track :) , can be an automatic gerbox shunt or something like that ;)
    as soon as I find I'll put it all that can always serve ;)
  11. thesnake108
    May 14, 2018
    16
    1
    Gender:
    Male
    it's running ^^
    I'm really happy, but I still have a problem that just happened, the first start it really good, slow idle stable etc,..... but the second start it oscillates in slow but it take all the rpm very good , do you know where I can look for this problem? (lambda, ? )
  12. George_R
    George_R Member
    Sep 13, 2010
    891
    16
    18
    Gender:
    Male
    DSP engineer
    Russia, Moscow
    Home Page:
    Well in my own opinion you lost in the very moment you decided to put nonvvti engine with stock management
    its self diagnostic features are minimal, as well as power output and MPG
    This thing however will serve as a scan tool for you
    https://zf-scantools.com/index.php?rt=product/product&product_id=126
    its inventor and seller lives in Canada and he speaks French
    Common reason for idle rpm oscillation with AFM controlled system is air leak. However there are tens of other possibilities
  13. thesnake108
    May 14, 2018
    16
    1
    Gender:
    Male
    Thank you ,
    I checked all the air intakes and actually there was one that I had not seen at reassembly, for the moment it turns out well.
    next road test I'll take you to the curent;)
