Megasquirt 2 help needed
Discussion in 'Stand Alone ECU' started by MtyMseHarmer, Dec 24, 2017.
  1. MtyMseHarmer
    MtyMseHarmer New Member
    Dec 1, 2005
    10
    1
    SCCA Rally/Solo Program Manager
    Topeka
    have a non-vvti in my 82 Supra. Picked up a Megasquirt 2 with 3.57 for it. Running factory ignition. Megasquirt has a Zeal daughter board for the Cam Sensor. Problem I am having is the left coil is causing too much noise for the cam and crank to sync correctly. Removing the left coil fuse gives a perfect composite log so I know the problem is noise. Any suggestions?
  2. gloverman
    gloverman Active Member
    Oct 15, 2004
    2,521
    22
    38
    mechanic
    Hamilton. New Zealand
    Are you using shielded wire for the cam sensor? Due to their tendency to suffer noise issues I often use shielded wires for the tps too.
