LPG and wasted spark?
Discussion in 'Alternative Fuel' started by 1uz head, Jan 25, 2010.
  1. 1uz head
    1uz head New Member
    Dec 16, 2009
    4
    Work
    NSW
    Hi all, just a question about spark.
    I am planning an LPG conversion on my 1uz using a 500 cfm Gas Research carby and Megasquirt ecu using 4 holden commodore coils in wasted spark mode.
    Can anyone see and problems with this? I am just concerned about backfires. The standard coils and leads may not be up to it if I decide to FI it in the future.
    thanks.
  2. Zuffen
    Jan 21, 2004
    5,280
    12
    38
    Retired Insurer
    Sydney, Australia
    You should be fine with wasted spark.
    Running gas or fuel won't make any difference to the "backfire" risk.
    Some of us run 20+psi on the standard ignition and it runs fine.
  3. madmont
    madmont Member
    Apr 1, 2004
    394
    16
    toolmaker
    Brisbane Queensland
    Just out of interest where would you you expect the backfire to come from?
  4. 1uz head
    1uz head New Member
    Dec 16, 2009
    4
    Work
    NSW
    I had a problem with a lpg 351 motor in a f100 once. When I ran a dizzy it was fine but when I went to wasted spark we had backfires through the carby with the same timing. I figured it was because of the after market cam spec but was never sure. It had to go back to dizzy. I was thinking there may be a reason they used the twin dizzy setup over coil packs from factory and thought it best to check.
  5. XR8tt
    XR8tt Moderator
    Jul 8, 2007
    2,761
    36
    Lineworker
    Sydney Australia
    Weak or incorrect ignition timing is usually the reason for backfire..
    Backfire out of inlet.. The reason why most std LPG engines run springs on there aircleaners...Doesn't always stop damage though...
  6. zen
    zen New Member
    Feb 1, 2009
    491
    fitter
    england
    sequential injection...no single point lpg crap...very cheap now..no backfires ever again..
