Long shot, but B/W / Tremec T5 question?????
Discussion in 'Drivetrain (Members Only)' started by cjsupra90, Mar 2, 2008.
  1. cjsupra90
    cjsupra90 New Member
    Aug 5, 2005
    1,024
    designer / welder / fabricator
    Lakeland, Florida - US
    Hey guy's, I am wondering if anyone happens to have or know where I can get a drawing or bolt pattern layout for the bellhousing to tranny main case mating location (Ford main case, not early GM main case)?
    I know that the T5 tranny's are not the stronges things out there, but I accidently came across a local guy selling a G-Froce T5 gear set, upgraded main shaft and steel shift forks. About $2500 worth of stuff for $750 dollars and has an extra stock T5 trans that he'll through in for an additional $250. This setup is said to be able to hold 500+ ft/lbs of torque by G-Force on a 3300lb car running drag radial's on the track, and more if in a street car running street tires.
    I dont want to pass it up, but I dont want to buy something that I cant end up making an adapter (T5 to 1uz bellhousing) for and then have to turn around and try to sell it.
    So if anyone has a drawing or knows where I can find one, and can let me know, it would be greatly appreicated that way I I can get started on a drawing for the adapter.
    Thanks in advance.
  2. autronic
    autronic Moderator
    Jun 22, 2003
    330
    1
    IT
    Bergen, Norway
    Check your mail.
  3. cjsupra90
    Aug 5, 2005
    1,024
    Ok, just got this directly from Tremec and figured I would post it incase anyone might need it at some point. Being directly from Tremec, Accuracy is dead on.
  4. cjsupra90
    Aug 5, 2005
    1,024
    oh, the drawing is for the standard Ford case T5
  5. Lextreme
    Lextreme Just call me "Lex"
    Mar 6, 2003
    12,051
    Professional
    City of Halos
    Home Page:
    Would that be similar to TKO600?
  6. cjsupra90
    Aug 5, 2005
    1,024
    Close, but no. the TKO have the same pattern as the old ford top loader cases
  7. autronic
    autronic Moderator
    Jun 22, 2003
    330
    1
    IT
    Bergen, Norway
    Here is a picture of the 1UZFE to BorgWarner T5 drawing.
    If somebody want Autocad or SolidWorks drawings, give me a holler.
  8. CJV8
    CJV8 New Member
    Jul 2, 2008
    9
    Development Engineer
    Newcastle upon Tyne, UK
    cjSupra90, did you ever get this installation sorted out?
    If so, what clutch arrangement did you use?
    I'm looking at using this setup in my car but don't know of a solution.
    I'm looking to use a modified 3SGTE flywheel, but I don't think there are any Toyota clutches which have a disc with a 10spline 1-1/16" centre.
    Any help appreciated.
    Cheers,
    Chris.
  9. markstoys
    markstoys New Member
    Jan 23, 2007
    147
    welder/fabricator
    Duarte, CA, USA
    It shouldn't be too hard to find a local clutch shop that can put any spline you want on a Toyota disc. I had a shop put the spline pattern for a T56 onto a Supra cluch disc for me.
    I think the last place I checked was Centerforce. On the website there is an application guide chart that lists the clutch size and spline info. You may find something that will work (unfortunately, I did not).
    Mark
  10. autronic
    autronic Moderator
    Jun 22, 2003
    330
    1
    IT
    Bergen, Norway
    CJV8:
    The 10 spline Chevy input shaft can use clutches from 10 spline BMW's so there should not be to
    difficult to find a clutch plate.
    Will send you an e-mail later with the 1UZFE/T5 drawings.
  11. cjsupra90
    Aug 5, 2005
    1,024
    You could have one made as mentioned, or another option is to use the disc form a BW trans'ed SVO mustang (5speed car not 4speed car). That clutch disc is a 8 7/8" with the 10spline 1 1/16" and although about 10mm smaller, will still work with a toyota pressure plate. My oppinion though is to have one made.
  12. Kenm
    Kenm New Member
    Nov 12, 2014
    1
    Glass blower
    Santa Clara, ca us
    T5 adapter drawings
    Hello,
    I found this old thread, I am looking for cad drawings of an adaptor plate for a 1uz bell housing to t5 trans. Any help would be appreciated.
  13. Sunday86
    Sunday86 New Member
    Jul 20, 2018
    1
    1
    Gender:
    Male
    Hi everyone, i am planning to swap engine from rover v8 to 1UZ in my Cobra replica.
    I know that this subject is quite old but if someone has cad drawings for 1uz to T5 trans i would be very interessed.
    Thanks a lot.
    St├ęphane.
  14. melvinmelvin
    melvinmelvin Member
    Sep 24, 2012
    262
    2
    18
    Not much
    Bangkok
    kinda an aside and off topic,
    but back in the ice age I had a Rover V8 bent into a Austin H - fantastic
    wow, what a car and eye (ear) turner
