Is this the definitive A650e manual swap wiring solution?
Discussion in 'Drivetrain (Members Only)' started by eicca, Oct 4, 2016.
  1. eicca
    eicca New Member
    Aug 17, 2016
    7
    1
    College student
    Utah
    Ok. This thread popped up on ClubLexus. Credit to maxEX84. It appears to deal with the subject of tricking the ECU to think everything is OK when doing an A650e-to-manual swap.
    The wiring issue was one of the biggest things I needed to see a solution for before I considered a manual swap. I wanted to post this solution here and see what y'all experts say because the thread hasn't received any attention on CL. I figure if it's the answer to the wiring conundrum then it might have received a little more recognition by now.
    If that's all it takes to make the ECU chill out, then it's no problem at all.
  2. George_R
    George_R Member
    Sep 13, 2010
    812
    1
    18
    Gender:
    Male
    DSP engineer
    Russia, Moscow
    Home Page:
    It's definitely not enough
    Both speed sensor should be properly emulated too, otherwise power limit will occur
    I have hardware solution
  3. eicca
    eicca New Member
    Aug 17, 2016
    7
    1
    College student
    Utah
    Makes sense. I searched further on the issue, someone said that the power limit is bypassed if the gear selector plug is jumped across the "neutral" pins so the ECU thinks it's in neutral. Feasible?
    What is your hardware solution?
  4. George_R
    George_R Member
    Sep 13, 2010
    812
    1
    18
    Gender:
    Male
    DSP engineer
    Russia, Moscow
    Home Page:
