how do you repair a cylinder with low compression
Discussion in 'Repair & Maintenance Tutorials (DIY)' started by Bighen, Jun 23, 2010.
  1. Bighen
    Bighen New Member
    Jun 23, 2010
    2
    Mechanic
    Flint Mi USA
    can someone send me a diagram on a cylinder head for a 91 ls 400. How can you repair a cylinder with low compression?:confused:
  2. XR8tt
    XR8tt Moderator
    Jul 8, 2007
    2,761
    36
    Lineworker
    Sydney Australia
    You've got a combustion leak..
    It's either a leaking head gasket.. Or through the valves.. One way to check if it's down through the rings, is to squirt about 5 or 6 cc [teaspoon] through spark plug hole. Turn engine over a couple of times.. Then check compression.. If it rises alot it's leaking down through rings..
    Check to see there is a tight valve clearance holding the valve open ??
    Check clearance when lobe on the cylinder is facing up...
  3. sideshow
    sideshow New Member
    Aug 31, 2003
    2,404
    boo
    Qld
    goto your local auto parts shop and buy a can of compression
  4. samsdad
    samsdad Member
    Aug 23, 2008
    559
    16
    petrol and diesel mechanic
    Perth WA
    I sent the work experience boy off once for a tin of compressed air.. He came back with a Truck air tank. Later sent the same guy out for a long weight. He went across the road to the pub and won $700 on the pokies and took us all out for dinner. I later suggested to the boss that we should see if he could get a skyhook. My workmate got all upset as he knew someone that did get one (a sky hook). That person that got one was me and my boss (at the time) was not too impressed with the big bill from Sikorsky Helicopters.. I got him a hook from a Sky Crane helicopter...10K USD thank you at the time..
    On subject you either have a burnt valve or rings gone.. Time to freshen the motor up
