Grounding 1UZ ECU casing in a fibreglass car
Discussion in 'General Discussion' started by Mat Grant, Apr 3, 2018.
  1. Mat Grant
    Mat Grant Member
    Jul 11, 2008
    139
    2
    18
    project manager
    southern UK
    Hi all,
    I've fitted a 1UZ to a Lotus, it is running, but the ECU is not bolted in yet, just sitting on the floor of the passenger footwell. I was planning on mounting it at the end of the passenger footwell, using rubber shockmount fittings, and install a cut down version of the plastic cover from the Soarer the engine was taken from. The car is made of fibreglass, so my question is, does the ECU casing need to be separately grounded? If so would tapping into one of the ECU grounds be adequate, or should I run a ground wire to a ground point on the chassis/pedal box? Or does it have a built in ground for the casing? (makes mental note to test this in the car)
    Any advice or suggestions welcome... For info my ECU is the 1992 Soarer three plug 40:40:40 type.
    Thanks, Mat
    P.S. sorry if this is in the wrong section.
  2. cribbj
    Jun 10, 2004
    4,725
    6
    38
    Gender:
    Male
    Consultant
    Houston, TX
    In general, it's bad practice to mix instrument (ECU & low level inputs) grounds with power grounds and other noisy sources (injection, ignition, etc.). So my kneejerk recommendation would be to try and run a separate ground for the ECU and its inputs.
  3. Zuffen
    Jan 21, 2004
    5,281
    12
    38
    Retired Insurer
    Sydney, Australia
    My ECU is in a Fibreglass body and it isn't grounded and never has been.
  4. melvinmelvin
    melvinmelvin Member
    Sep 24, 2012
    262
    2
    18
    Not much
    Bangkok
    mine likewise, not grp but acryl plastic box, no separate grounding
  5. Mat Grant
    Mat Grant Member
    Jul 11, 2008
    139
    2
    18
    project manager
    southern UK
    Thanks guys, that's one less thing to worry about.
    Cheers, Mat.
