Difference ECUs 89661-50241 and 89661-50240
Discussion in 'Fuel, Ignition, Air, & Tuning (FIAT) (Members On' started by melvinmelvin, Dec 19, 2015.
Tags:
  1. melvinmelvin
    melvinmelvin Member
    Sep 24, 2012
    120
    16
    Not much
    Bangkok
    When I first got my 1UZ it had ECU 50241.
    Since then I have screwed up 3 ECUs.
    Could not get hold of 50241 used 50240 in stead, to me seems the engine
    is running just fine with 50240.
    Although, I wonder if somebody knows the difference between the two.
  2. gloverman
    gloverman Active Member
    Oct 15, 2004
    2,366
    6
    38
    mechanic
    Hamilton. New Zealand
    The last number on the toyota part number is the supercession number. So the 241 is a later replacement for the 240. They should interchange without any issues.
  3. melvinmelvin
    melvinmelvin Member
    Sep 24, 2012
    120
    16
    Not much
    Bangkok
    thanks a lot. ta.
  4. EyesofThunder
    EyesofThunder New Member
    Sep 28, 2011
    87
    RF Technician
    Rockford, IL, USA
    What happened to your ECU's? I fix GM ECM/PCM's, I could take a crack at it if they are sitting collecting dust.
  5. melvinmelvin
    melvinmelvin Member
    Sep 24, 2012
    120
    16
    Not much
    Bangkok
    Collecting dust they are.
    I have my 1UZ in a boat, the boat sunk, twice.
    The ECUs didn't work after that, no surprise really.
    One ECU sat on a shelf for 6 weeks, while I was out of the country, hauled the engine before I left.
    When firing up again after returning the ECU works but only for 7 cylinders.
