Project Thread Clean400's Centrifugal Supercharged Nitrous 1UZ
Clean400
Vancouver
Clean400's Centrifugal Supercharged Nitrous 1UZ​
Let's start off with the mods I've done so far.
Suspension Setup: NF210 / Tokico Blues
Comfortable suspension, more sporty than stock. Only a slight drop. Great for people who want to keep that Lexus feel. Suspension is very smooth. Inexpensive too. This combo was only $500. I chose it after it being so well recommended on these forums. :thumbup:
Poly eurathane Steering Rack Mounts made the car's steering feel much sportier, tighter and responsive. :thumbup:
Ebay front strut bar made a very small but noticeable difference. I didn't think I would actually notice it. Maybe it's a placebo lol :thumbup:
Wheels: TRD Sports18"
18x9.5 rear and 18x8.5 front. These are TRD Sports in Supra offset sizing with 40 front and 38 rear. They were sold to me as "TRD T3's" from this JDM shop near me but they are in fact TRD Sports wheels in Supra offset sizing. What's interesting is that TRD Sports wheels are not listed as coming in these offsets on the TRD website. My friend has TRD T3's and they are indeed a different design than the TRD Sports that I have.
http://www.trdparts.jp/english/parts_wheel-sport.html
Overall a great wheel. Only weigh 17-18 pounds a piece. Improved handling, acceleration and braking. Everything about the car felt better. Never realized good wheels would much such a difference. :thumbup:
Transmission & Differential Transgo HD2 Shift Kit, 4th Solenoid Mod, B&M Trans Cooler 70264, 2800RPM Torque Converter Converter, Torsen JDM Supra N/A 4.08 Gear Differential
I have the Transgo HD2 Shift kit on hot setting. Chirps the tires when it shifts. Car feels much faster with it. Best mod for the A340 transmission. This mod is a must if you're planning on boosting with the stock auto.
Link to Transgo Shift Kit Thread
I have the 4th solenoid mod wired on a switch. When the solenoid is off, you can really tell the increased line pressure through the transmission. By moving the shift lever from park to drive it really jerks hard into drive. With the solenoid on, it doesn't have this huge jerk. Since I have the Transgo Shift Kit I already have boosted line pressure so the effects of the 4th solenoid mod are more pronounced. Although I do notice the increased line pressure when switching from park to drive, the increased line pressure is not noticed when going WOT or changing gears. This is probably because the 4th solenoid is there to gradually increase the line pressure. So with the 4th solenoid set to on, my line pressure at a stop is normal and then increased to full line pressure when shifting at WOT. With the 4th solenoid mod off, my line pressure is at max all the time.
For these reasons, I actually just drive around with the 4th solenoid mod ON like stock. I have comfortable lexus like shifting at low speed and great crisp shifting with the Transgo at WOT. I have to do further testing if the increased pressure of the 4th solenoid mod gives me better times, but to be honest from a seat of the pants feeling it does not. I could see if someone did not have the Transgo kit, that the 4th solenoid mod would be a very small upgrade. The 4th solenoid mod however does not compare to the effect of the Transgo shift kit at all.
I have the Hot Rod setting on my Transgo kit. The hot rod setting is simply the size you drill the holes in your valve body. The kit comes with two drill bits; Truck sized and Hot Rod sized. The hot sized are larger and will make your auto chirp your tires during WOT shifts. It is a great setting for fun but for all out 1/4 mile time performance it is probably not. I think a drill size between truck and hot rod would be ideal. I've never tried truck setting, but if you were you could start with it and then go up from there. I'd imagine a drill bit size right under Hot Rod would be just perfect. I'm just worried when I slap on my supercharger that my rear is going to get squirly on shfits with Hot Rod settings. Transgo shift kit a huge thumbs up :thumbup:
2800rpm converter, Torsen differential and 4.08 gears were all installed at once. This made a dramatic effect on launch characteristics of the car. The combination of the three made flooring it off launch incredibly fun. The car felt a lot faster form a seat of the pants feeling. The driving characteristics of the Torsen are also much better than the open differential. For example, I had the shift kit installed with the open differential, and when it was raining I went full WOT 1-2 shift and the car bucked sideways completely. With the Torsen differential everything is smooth and in control, so you can have fun at the limit. Installed poly eurathane differential mounts as well. Overall these upgrades were a huge plus :thumbup:
Supra Mishimoto Radiator: Temps are cooler. Looks good. There is a thread somewhere on clublexus to show how to install it and use your stock fan shroud. You just have to flip the stock rad mounts upside down underneathe to raise the Mishimoto to the right height. Install looks spot on, looks like it was almost meant to be stock. Works great with the stock fan and shroud :thumbup:
Brakes: LS400 BBK, SS Lines, Semi-Metallic Pads (soon to be switched back to ceramic).
Great stopping power over stock. The LS400 calipers are much better than the stock sc400 fronts. The semi-metallic pads bite extremely hard. The only downfall of the semi-metallic pads is that they squeal. For this reason I will be switching back to ceramic pads, but if you want strong brake bite use semi-metallic you won't be let down. :thumbup:
Cosmetic:
Green Lip & B-Pillars: The matching B-pillars with the rest of the car bring the look up to date. The black b-pillars with the green looked kind of old school. Looks much better in my own opinion. The matching front lip with the rest of the car looks much sleeker. :thumbup:
95 Tails & High Beams: Glass high beams look better than plastic. 95 Tails are the nicest tails in my opinion. I have hyper blink which I will try to fix with some resistors one day. :thumbup:
ES300 Wood Steering: Great looking steering wheel. I had my steering wheel leather refinished to match the grey interior of the car. The wood model es300 steering wheel I chose matches the wood on the SC400 interior. Looks classy and much better than the original steering wheel. :thumbup:
Audio:
F700BT Pioneer in modified metra bracket (see thread on clublexus. Metra bracket sucks without modification). Looks flush in the dash. Updates the look of the car over the stock radio. 6.5" Infinity Components and 10" Lightning Audio subwoofer powered by a 4 Channel Lightning Audio Amplifer. Modified the stock speaker pods on the doors to accommodate 6.5" speakers. Made brackets for 6.5" speakers in the rear deck. Amp and sub are not in the car right now but will be in soon. The stock Nakimichi system sounded amazing though, I still regret removing it. When my new amplifier gets intalled and my speakers get amplified again I'll be happy. :thumbup:
Nitrous: Nano Nitrous, Wet Kit, Zex Window Switch & TPS (Soon to be upgraded to NX Maximizer 4)
My Nitrous Guide Thread
I'm using a Nano Nitrous setup. It is a second bottle filled with compressed air that keeps the nitrous bottle constantly at 950psi. Usually a bottle warmer is needed to get the nitrous to this PSI. The advantage to this setup is that you are always ready to boost, it is easier to tune, it makes the nitrous hit harder and your PSI stays constant right until' the end of the run. Overall I couldn't be happier with the setup as it removes all the disadvantages of nitrous (except refilling the bottle). Currently my nitrous system is only using 50 shot jets. My current controller is a straight shot controller. My plan was to install a progressive system and run a 150 shot. My plans changed when I bought my supercharger though. New plan is to install 75 jets and use the NX 4 Maximizer controller to spray nitrous in 2nd and 3rd gear on top of the boost of the supercharger. Plans get upgraded but that's the safe plan for now.
Parts waiting to be installed
  • AEM FIC 8: I will use one map for the supercharger and the other for supercharger + nitrous.
  • AEM Failsafe Wideband
  • NX Maxmizer 4: Progressive nitrous controller that I will spray nitrous in 2nd and 3rd gear. I will avoid spraying nitrous in 1st gear until' I upgrade the 2nd gear sprag. The 2nd gear sprag in the A340 can only handle about 340whp. With 6psi, will be around 300whp hopefully. The 75 shot of nitrous should get me close to 400whp because the boost increases the effect of nitrous. Once I build my auto with an ATF billet 2nd gear sprag and Red Alto HD clutches, I'll up the boost and the nitrous (but this will only be in a few years).
  • GTspec Rear Strut Bar
  • Denso Supra TT F/P
  • Titan Line Lock Kit
  • Two Jeniko Nitrous Bottle Brackets for easy removal of bottles
  • Tweaked performance patch harness for FIC 8
Centrifugal Supercharger Build:
Bought a Vortech V3 Si off ebay for $650. It needs a rebuild though. I ordered the rebuild kit from superchargerrebuilds.com with a mechanical seal. Cost for the rebuild kit was $225.
So today I ordered a bunch of parts to get this fishbracket build going. It's called the fishbracket build because the bracket that holds the supercharger looks like a fish. Did a lot of research to find the right parts for the job. Thanks to members of Lextreme, Clublexus and Supraforums for all the info posted online.
Bypass Valve: Audi TT and Porsche 710N Bypass Valve
Part # 06A 145 710 N
This is what the mustang guys use to upgrade the bypass valve that comes with the vortech kits. The 710N has metal internals and is great bang for the buck. Only $50!
Dual Electric Fan Conversion:
Unfortunately for the SC400, the dual electric fan conversion is needed for space reasons. I don't think it's needed for the LS400 though. The stock fan setup of the SC400 is great, high flow and reliable so it's a shame to take it out. I had to do a lot of research to find a good bang for the buck setup. A lot of the shroud kits out there are not well rated by the Supra community except for one which is pretty pricey, it actually uses is300 fans which are really good.
In the end I ended up going witha two 14" Zirgo ZFUS14 setup.
This dual Zirgo setup was well recommended by the supra community. Plenty of people use these two fans without a shroud, so I will be going down this route. Total cost for the two fans was $260
The fan controller I ordered was Flex-A-Lite 31163. This is a variable fan controller that has a lot of nice features for the money. It has good reviews online. Cost was $165
LS400 Fan Bracket and Pulley
This is needed for the fishbracket.
Cost was $57 shipped online. I ordered a cheap non-oem part. Hopefully it holds up.
The Pulley does not come with the fan bracket. The part number for the pulley is 16371. I ordered this from Lexus of South Atlanta for $70 shipped. That was the cheapest price I could find it.
Next up I need to choose my pulley for the supercharger. I plan to start with 6psi non intercooled. This should be plenty fun to start with and should give me an estimated 300whp. I plan to try to use my stock injectors, if I see they are not up to par I will upgrade them to 7M green injectors 315cc.
For the pulley I'm having difficulty in choosing the size I want to order. I'm thinking of ordering 3.48" to give me about 6psi. Any feedback would be much appreciated.
All that's left to buy is the vortech pulley, belt, piping and some miscellanious wiring to relocate the battery to the trunk. I also have to copy the EGR Delete & Fishbracket that my friend's have (would order from lextreme but parts ordering is hopefully only temporarily closed). Apparently the EGR delete is necessary or you won't build boost (you get boost leaks). From what I read I need 7/16" x 127mm bolts and 103mm spacers (the spacers I'm not 100% sure, this is from what I read on a forum). It's too bad I can't order the bolts and spacers directly from Lextreme right now.
This 6psi non-intercooled setup with a 75hp shot of progressive nitrous should be pretty fun. After enjoying this setup for a few years the plan is to go built auto, slap on an intercooler and crank up the boost. The neat thing about the nitrous is that I can spray in 2nd and 3rd gear and avoid busting the 2nd gear sprag on 1-2 shift which is the weak link of the stock A340.
Super excited to get this supercharger build started! I'm away from home for work until' October, so all I can do right now is read on forums and learn more about this setup. The plan is to get everything done before winter comes so that way I can enjoy the car at the start of next summer. Here's hoping everything goes well.
The plan is to have the supercharger piping setup looking like this (not my car. SPF's car who is on Lextreme.):
Thanks. Hey Steve how's your built auto holding up? What's your auto build?
It's fine. No problem so far. I'd expect it to last for a very long time. I have IPT shift kit, Alto Red hi-performance overhaul parts, and Lextreme TC. I also have a separate tranny cooler and I use full synthetic tranny fluid.
Nice that is very promising. I would be going with the Red Alto HD clutches too. I was also considering the ATF billet 2nd gear sprag. Your running close to 400whp and the stock 2nd gear sprag is said to break around 340whp so maybe it can handle more than I thought.
That's what some said on the 2nd gear sprag, but I doubt it. I run close to 400 whp, but the torque is more than that. The torque is what breaks things apart. I launch very hard, but I don't do break-torque. I think break-torque kills the gear sprag, tranny, or torque converter.
Nice. Maybe I won't have to buy that expensive 2nd gear sprag from ATF afterall. It's so expensive at $800.
I did some more shopping and got some more needed parts for the build.
Battery Relocation kit with Box and Wires for $100. From a seller called merchantsellers on ebay.
Ordered Lextreme EGR delete kit off of a clublexus member. $90
Ordered 3.48" Pulley. $90 shipped. Hopefully this gives the desired 6psi.
I did research on the spacers that I needed. Mickesandra who has a vortech v3 si build said his spacers ended up being 105mm.
Onlinemetals.com sells stainless steel tubing that can be cut to specific length.
Stainless T-304/304L
Seamless Tube
0.75" x 0.12" x 0.51"
Cut to: 4.1339"
6 spacers would cost $73 shipped. I almost ordered it but decided to wait to make my own measurements. I wouldn't want to waste $73. I'll probably source some stainless steel tubing locally.
So all I need now is the 7/16" x 5" bolts, spacers, fishbracket and piping. I posted an ad that I was looking to buy a fishbracket on clublexus. These are getting hard to find since Lextreme isn't selling parts anymore. It would be so much easier if I could buy his bolt and spacers kit! Someone should start producing these again. Soon there will be none left on the used market. I'm probably going to have to copy my friend's fishbracket.
Now that my buying spree has come to an end I'll be patiently waiting to return home at the end of the month and getting this build started. :thumbup:
Centrifugal Setup Checklist:
1. Use a Bypass Valve
2. Use a piggyback/standalone to control fuel tuning
3. Don't go over 7psi on stock injectors.
4. Block the EGR
5. Dont' use a BOV (Bad idea with a MAF setup. If your using MAP it's okay but centrifugal's from what I read work best with bypass valves).
When you build the tranny, it's better to use the master overhaul kit. It has everything in it. With all of tranny mods I have, the tranny temp is a lot cooler. I can touch the tranny cooler with bare hands after I drive the car in summer. It's only warm. The tranny only breaks down when it's over heated. So if it's warm, then it's all good.
Before the tranny mods, I could feel the heat from inside the car when I touched the carpet near the shifter. That's how hot it got. The high stall speed torque converter makes the tranny a lot hotter. It actually breaks the stock tranny a lot sooner. I guess not everyone is aware of that. But when all good mods are combined, then the torque converter actually helps big time, and the tranny will last a long time.
So I was talking with my tuner about my idea to go non-intercooled and he was super against it. So I told him I would order an air to air intercooler then and he asked if I ever considered an water to air intercooler. I said I never did because I thought they would cost a lot. In the end it wouldn't be that much more or about the same as an air to air setup.
My idea is to use this piping setup that this 1uz supra vortech guy did in this youtube video. This piping setup is super simple. Where the pipe is straight after the supercharger, I'm going to put a water to air intercooler.
V8 supra 1uzfe vortech supercharger lexus - YouTube
Ordered the water to air intercooler from frozenboost.com. I also ordered silicone bends, t-bolts, v-bands etc. from them. This should be all of the piping that I will need to complete the intake. I pretty much eyeballed everything from the supra 1uz supercharged youtube video lol. I'm working abroad and I don't have my car with me to do any measurements.
edit: **** just realized I ****ed up my order. It should have been a 3.5" clamp not a 3.75"! This is for the supercharger inlet.
Total cost $635
The intake before the supercharger will be designed like spf_lexus's build on lextreme. The intake will be a 90 degree 3.5" to 4" reducer silicone piece, that will connect to a 90 degree 4" aluminum bend. This will then connect to a 4" K&N. From what I read off spf_lexus's build the intake should be 1/4" to 1/2" larger than the supercharger inlet. Plus this will grab cold air versus hot air from inside the engine bay.
SPF_Lexus's Car (not mine)
Spectre 9798 90° Air Intake Tube $20
K&N Universal 4'' Air Intake Cone Filter 102mm RU-2510 $34
Ordered those spacers I was talking about before:
6 pieces @ $7.31/piece
Seamless Tube
Cut to: 4.1339"
1 piece @ $86.33/piece
Mild Steel A36
Hot Rolled Plate
0.25"
Cut to: 24" x 36"
Also ordered a plate of mild steel to make a copy of my friend's fishbracket. Total cost $168 from onlinemetals.com
Ordered two packs of 5 grade 8 bolts for $20. Only need 6 but they came in packs of 5.
Grade 8 Hex Cap Screw Bolts 7/16-14X5" 5PC
Ordered this MAF Sensor adapter. $23
Detailing all of the costs and parts to keep track. Also for everyone else thinking of doing this build :thumbup:
I think I'll be much happier with the water to air intercooled setup. The response should be much better using this shorter piping setup versus a longer air to air setup. My only concern is heatsoak with the intercooler being right between the radiator and engine. If there is significant heatsoak, the intercooler will be placed in the front bumper area, similar to where a standard FMIC setup would go. Hopefully the intercooler is fine where I'm planning on putting it, because this would be a very short piping setup which would give great response. It's also a much cheaper and easier piping route.
Now that I've ordered all the parts I'm more anxious than ever to get this build started. I'm only concerned with the stock MAF's ability to take boost because of all the problems I read with it. I'll put some sealant on the maf sensor plastic like spf_lexus did. If the stock MAF starts to be a pain, I'll switch over to standalone and map. For now the FIC 8 is the plan. I'm considering ordering 315cc injectors right away but I think I'll just start with the 250cc injectors for the 6psi break-in setup. Once everything is running properly I'll throw in the bigger injectors and a smaller pulley to try out 9psi. Before 9psi I will have to upgrade my exhaust though, it will be hurricane long tubes. I'm always thinking two steps ahead so I'll stop writing now lol!!! Let's just hope this all works for now! :thumbup:
Edit: Ordered a bit more.
Ordered Verocious Vacuum line starter kit.
$85. Replacing all the vacuum lines before the build starts.
Ordered a water to air installation kit from votionspeed
As well as 4" piping incase the K&N filter needs to go lower for clearance. I also ordered a 3.5" t-bolt and another 4" t-bolt. All this was $100 shipped. Votionspeed seemed to have all the exact same products as frozenboost. My water to air cooler kit I ordered from frozenboost was cheaper on votionspeed by about $20.
Anyways that's all for tonight! Have to go to work tired now after staying up so late figuring out which parts to order lol.
If you run low boost like 6-7 psi, then there's no need for an intercooler. By the look of that water-air cooler, I don't think it's as efficient as air-air cooler. Air-air cooler can be had for around $150 on Ebay.
Link for the master overhaul kit? It's the first time I've heard of it.
You can contact http://www.altousa.com/ and ask for the Red Eagle master overhaul kit. I lost the receipt of what I bought, but here's the email I received from Alto. Again, you need to contact Alto directly for complete instruction on what parts to buy.
"Yes, these parts fit both the A340E & A341E transmissions.
Your application should use a total of (5) 073742 frictions plates.
The 073752HP module contains (4) therefore you will need to order the (1) 073742 extra individually (so you will have a total of 5).
The last two parts listed are not must have items. The 073753F module contains all of the steel plates that you will need but none of them are Kolene treated.
So, order the bottom two item only if you want what we have available in Kolene."
