A341E solenoid control question
Discussion in 'Drivetrain (Members Only)' started by SpeedLove, Jun 23, 2018.
Tags:
  1. SpeedLove
    SpeedLove New Member
    Jun 20, 2018
    2
    1
    Gender:
    Male
    Hello. My understanding is that the foward 4 gears in an Aisin A341 are controlled by 2 solenoids on the valve body, and the trans is controlled by the ECU. S1 on S2 off = 1st. S1, S2 on = 2nd. S1 off S2 on = 3rd. S1, S2 off = 4th.
    So, Im planning to wire the 2 shift solenoids on my ucf11 LS400 to 2 switches on the center console to manually control the transmission full time.
    I know this can be done with an aftermarket/diy controller but I havent found any information on whether or not the ECU will go into limp mode with the trans outputs disconnected.
    Has anyone tried directly wiring the solenoids to manual switches with no controller? Anyone had issues with this? Thanks
  2. gloverman
    gloverman Well-Known Member
    Oct 15, 2004
    2,724
    63
    48
    mechanic
    Hamilton. New Zealand
    If wired correctly it will work fine, just like when run as a manual.
