92 1UZFE LS400 Engine plugs part #'s
Discussion in 'Electrical & Electronics (Interior)' started by Bollox, Jan 23, 2018.
  1. Bollox
    Bollox New Member
    Mar 12, 2011
    17
    1
    Construction
    Florida, USA
    This is a long shot, I'm building a new harness for my project and all the connector plugs are as dry and brittle as a popcorn fart. Would anyone by chance have a list of part numbers for all of the engine plugs?
    1. Crank sensor
    2. Cam Sensors same L & R
    3. Ignitors plugs (2) plus pins
    4. Injector connectors
    5. Knock sensors (2)
    6. Coil pack connectors (2)
    7. AFM
    8. Oil Pressure switch
    9. ICS connector
    10. TPS connector
    11. OEM ECU connector pins and plugs
  2. gloverman
    gloverman Well-Known Member
    Oct 15, 2004
    2,697
    55
    48
    mechanic
    Hamilton. New Zealand
    I dont know the part numbers but have some of those in stock. Crank , LH cam , Injectors , Knock(two options I have one), Coil , Oil pressure , ISC and TPS. I have the second series of gen 1 ecu main 28 pin plug as thats all I need when wiring stock harness and the earlier ECU 26 pin plug (same as VVti which I wire heaps of).
    I rebuilt a loom the other day with as many new plugs as I could.
  3. Bollox
    Bollox New Member
    Mar 12, 2011
    17
    1
    Construction
    Florida, USA
    That's a long way to send the connectors, I think they are made in the USA, well some of them at least, but I would like to ask you how much to ship them to me,
  4. Bollox
    Bollox New Member
    Mar 12, 2011
    17
    1
    Construction
    Florida, USA
    Also, I have a crank sensor, do you have the wiring for that, I think I have the pins round the wrong way,
  5. gloverman
    Oct 15, 2004
    2,697
    55
    48
    mechanic
    My injector plugs are Japanese, Real deal Nippon denso , I also have copies. Ill take some photos and get some pricing.
  6. Bollox
    Bollox New Member
    Mar 12, 2011
    17
    1
    Construction
    Florida, USA
    Thanks man appreciate it
  7. Jo Fletcher
    Jo Fletcher New Member
    Dec 30, 2017
    8
    1
    Hi mate, when you talk about the 28 pin plug are you referring to the 4th plug on the ecu?
  8. gloverman
    Oct 15, 2004
    2,697
    55
    48
    mechanic
    Yes thats the one. The 28 pin plug on the ECU. Does depend on the ECU you have as 92 is the year they change ECU pin counts.
  9. Jo Fletcher
    Dec 30, 2017
    8
    1
    Hi there I've got the 34 22 16 28 pin ecu.
  10. gloverman
    Oct 15, 2004
    2,697
    55
    48
    mechanic
    This one.
  11. gloverman
    Oct 15, 2004
    2,697
    55
    48
    mechanic
    Rear view
