fabre12
- 17
- Melbourne, Australia
Hello 1UZFE ppl, we are shoehorning this beast of an engine into our 2000 Jeep Wrangler. It seems that this has not been done as we cannot find much info. We have the engine running in the Jeep, and now we are trying to get the auto to work. It seems to be stuck in 1st gear. From what we've read, it needs the signal from the speed sensor at the back of the auto trans. The challenge is that we had to remove that housing to allow for the Jeep transfer case to be fitted. The Jeep uses a 3 wire speedo sensor on the transfer case, but we think the signals are different. We've tried to connect the Jeep sensor, but it does not seem to trigger the ecu to change gear. Even if we manually shift the trans with the shift lever, it will NOT change out of 1st. There may be issues which we are not aware of. We'd like to hook up the OD light to tell us if the trans is getting the signals it needs, but have not been able to find info. Sorry for the long post, but it's been driving us crazy.
