3UZ Shallow (or Dry) Sump & Accusump / Oil Accumulator
henk_k
Mid wales, UK
Hi,
Looking to get my 3UZ as low in the chassis as I can, and the sump is the limiting factor.
Has anyone run a shallower sump and an oil accumulator to compensate?
Or do I just man up and go full dry sump?
Engine will be stock for now, but future plans are forged, twin turbo, hopefully get the cams ground.
It's mid engine in a tube chassis (<1ton) with wide rubber so hope to be capable of some corner Gs!
Sadly couldn't find any info of the 3UZ that was used in the Doran Prototype...
A different position?
I could go with a wider and longer sump, but that would be pretty awkward to fabricate, bolts going through the whole sump or several bolted-together sections I guess
