1UZ VVTi / 3UZ / 2JZ stock ECU conversion for M/T
Discussion in 'Trade' started by George_R, Feb 23, 2017.
  1. George_R
    George_R Member
    Sep 13, 2010
    846
    2
    18
    Gender:
    Male
    DSP engineer
    Russia, Moscow
    Home Page:
    This offer is a device that eliminates limp home mode, which is otherwise active if ECU does not 'see' stock auto transmission.
    Earlier ECU models (1UZ non-vvt, 1jz, 2jz before 1998) didn't have "underpowered" fuel/spark/vvti (for the JZ) maps for N/P transmission range, so these ECUs are 'fooled' quite easily.
    Newer ECUs are not like that. Putting them in P or N will eliminate all fault codes, but engine power will be somewhat limited.
    My device solves the problem by simulating solenoids and input/output shaft rotation sensors, so the speed of 'rotation' corresponds to engine RPM and current gear.
    The only dyno sheet available so far is for 17x body Toyota Majesta engine in a 90-series MarkII
    It's not perfect and the 10% lack of torque can be explained by non-functional variable intake geometry system (ACIS)
    The device costs $100 USD shipped worldwide
  2. eicca
    eicca New Member
    Aug 16, 2016
    28
    1
    College student
    Utah
    The ACIS doesn't operate with the M/T device installed?
  3. George_R
    George_R Member
    Sep 13, 2010
    846
    2
    18
    Gender:
    Male
    DSP engineer
    Russia, Moscow
    Home Page:
    It will operate of course
    With my device, ECU thinks it has its stock a/t and performs accordingly
    It's test car problem, not related to my device
    Used ACIS control solenoids don't last for long. The owner didn't want to replace it with a new one
  4. eicca
    eicca New Member
    Aug 16, 2016
    28
    1
    College student
    Utah
    I see. Is it possible to plug your device into the tranny wiring harness? I'm still phobic about cutting up my ECU wiring harness.
  5. George_R
    George_R Member
    Sep 13, 2010
    846
    2
    18
    Gender:
    Male
    DSP engineer
    Russia, Moscow
    Home Page:
    Possible but correct operation is not guaranteed with long wires
    You can just undo loom pins from connector so the operation would be reversible
    Or buy a modified ecu from me which will not interfere with a/t loom
    eicca likes this.
  6. Lextech0634
    Lextech0634 New Member
    May 18, 2017
    1
    1
    Gender:
    Male
    How can I get this device? Is it still available? Will it work with a 3UZ out of a GS430?
  7. George_R
    George_R Member
    Sep 13, 2010
    846
    2
    18
    Gender:
    Male
    DSP engineer
    Russia, Moscow
    Home Page:
    Yes always available, works with GS430 ecu for 5-speed auto. 6-speed variant is under test now. Price 100 usd shipped. PM or email me for details
