1UZ Throttle body on 3UZ
Discussion in 'General Discussion' started by TomDK, Dec 6, 2018.
  1. TomDK
    TomDK New Member
    Jul 25, 2018
    4
    1
    Gender:
    Male
    Hi
    As the title says.
    Is this possible, putting the 1uz throttle body on a 3uz.
    Reason for this would of course be to have the cable operated throttle body instead of electronics.
    Have to find a new engine, as the 1uz I had bought turned out to be in a horrible state.
    Will be running Megasquirt ECU.
  2. gloverman
    gloverman Well-Known Member
    Oct 15, 2004
    2,710
    58
    48
    mechanic
    Hamilton. New Zealand
    Why not put a nicer aftermarket throttle body on if you are using an aftermarket throttle body? An early 1uz TB will need some adaption, a 1uz vvti TB bolts on but is still DBW even though it has a cable.
  3. TomDK
    TomDK New Member
    Jul 25, 2018
    4
    1
    Gender:
    Male
    What aftermarket TB would you suggest then? Was only considering the 1uz TB as I now have one lying around with no use of it :)
  4. gloverman
    Oct 15, 2004
    2,710
    58
    48
    mechanic
    Last 3uz I did with non stock Tb I used a 90mm aftermarket unit. I only did that as it was going to New Caledonia and i wasn't sure of their skills over there setting up the DBW if settings needed changing. Personally i like the stock 3uz unit. Sets up nicely with a good ecu. Fast operation and plenty of pedals which are available these days.
  5. TomDK
    TomDK New Member
    Jul 25, 2018
    4
    1
    Gender:
    Male
    Okay, ca see that it's nok hard to find a 90mm aftermarket TB. But are all bolt patterns universal?
    Just so much easier with the 1uz.... :)
  6. gloverman
    Oct 15, 2004
    2,710
    58
    48
    mechanic
    The universal aftermarket Throttle bodies (well over here anyway) come with a flange to adapt onto the engine. As you haven't stated which 1uz throttle body you have I dont know about bolt pattern. If you have a 1uz VVti DBW throttle body they do bolt on but still have electronics or if you have a Gen 1 or Gen 2 then they are a different pattern and would need an adaptor anyway. I did a video on youtube which might help
  7. PeterPete
    PeterPete New Member
    Jan 11, 2019
    1
    1
    Gender:
    Male
    Photographer
    Tampa, Florida
    Was about to ask the same thing. Thanks for the tip, gloverman!
