Project Thread 1UZ-T MK4 Supra
ugp
uk
Just got around to posting a project thread, I'll fill in all of the blanks tonight and do a full write up. For now, here's the only old picture of it that I can find:
attachment.php
It currently lives in this:
attachment.php
Thanks for the comments guys. I'm hoping for 1100. It ran 980 on a pair of smaller turbo's.
I'm awaiting new engine mounts and some ARP flywheel bolts.
Curious if you had any overheating issues and what your cooling system looks like? Could you describe any changes/upgrades that you made in that area?
Koyo radiator with twin electric fans and a stat that opened at 75 ish were the only changes made.
Temperatures sat at 85, rising to around 94 on full chat in short bursts. Long runs would have it creep upto 100, by this point both fans are on full tick (on at 87, off at 85).
These temps were reported by the stock sensor into the megasquirt, so I've no idea if they're exactly accurate.
Couple more photos guys:
A few more:
It's not something that's really required. The hottest it ever get's here is 20 degrees C, so as long as the heaters work I'm chuffed :). If we do get a sunny day the roof will be coming off (it's a targa top).
Blimey, not updated this in a while. Finally on the road and MOT'd. I've a couple more dyne sessions booked once I change the wastgate springs over, hoping to crack 1000bhp, but that won't be happening until the spring appears and all the salt goes.
Also in dire need of a the suspension setting up, it's like bambi on ice trying to lay any power down at the moment.
Here is the MKIV Supra suspension setup, AKA the Lance setup. Basically it's no toe on front, with all the caster (5 degrees) you can crank in, and minimum toe at the rear.
Camber settings aren't anything wild. 1 degree per wheel up front and 1.5 per wheel in back.
This is designed for good stable handling, and it should result in pretty light steering with all the caster, and even wear on tires. Those may not be your goals, but in lieu of anything else, it's a good start.
Give the image a click & it should open up into a new window where you can actually read it.
