1uz into s13 wiring help
edprowting
England, Southampton
Hi all I am a new poster on the forum but have been using info from here since I started my build so thanks for that ! very helpful.
I'm pretty certain I have the ecu wiring correct. How ever I don't know which wires I need to splice to put switched power to for the sensor, injector, coils and igniters.
Is there a plug in the loom somewhere with all of these together ? or is it a case of stripping the entire loom back and finding each individual + to each sensor etc and do it that way :S
Thanks in advance
They are all usually o the body plug on the ECU.
Depends which ECU/engine you're using but all the body wires need to come off one plug so the ECU?engine can be removed/installed easily.
