1uz-fe Auto box 1st gear kick down??
Discussion in 'Diagnostic & Repair Tech' started by Bhogg, Dec 29, 2017.
  1. Bhogg
    Bhogg New Member
    Feb 5, 2016
    17
    1
    Disability worker
    Victoria , Australia
    Hi All
    Just wondering if the 1uz-fe Auto box is meant to kick back/drop down from second/third gear to first gear?
    Due to my engine and box being put into another vehicle I’m wondering if there is something missing that makes it kick back to first or not!.
    I’m guessing there would be as it’s completely gutless if doing say 20 kmph and it’s in 2-3 gear and then put your foot down and there’s nothing no power due to in not dropping down to first gear!!.
    Any help would be greatly appreciated
  2. gloverman
    gloverman Well-Known Member
    Oct 15, 2004
    2,603
    34
    48
    mechanic
    Hamilton. New Zealand
    The early ecus have a kick down switch under the accelerator pedal which is often not fitted in conversions. This allows the ecu to kick down better. Its not a great system but it certainly improves transmission performance. I'm guessing your vehicle won't have it.
  3. Bhogg
    Bhogg New Member
    Feb 5, 2016
    17
    1
    Disability worker
    Ok cheers Gloverman so I’m guessing that kicks it back to first gear then?
    Thanks mate
  4. gloverman
    Oct 15, 2004
    2,603
    34
    48
    mechanic
    Yes depending on the conditions of coarse. Another wire thats often missed in the Brake switch input so the transmission often doesnt select 1st when the vehicle comes to a stop after driving so they start off in second gear making them slugish. The TPS dont read full 100% so thats why the kick down switch is required on the early. I prefer the Gen 2 ecu as thay have better Mapping for engine and transmission. No kick down switch required.
  5. melvinmelvin
    melvinmelvin Member
    Sep 24, 2012
    248
    2
    18
    Not much
    Bangkok
    since this is about the 1UZ auto gearbox, may I sneak in a related question;
    can the gearbox be set up so that when the stick is put into 3 or D or whatever it says on the gear console,
    the gearbox goes to the highest gear and stays there, regardless, until the stick is moved to Neutral position?
  6. gloverman
    Oct 15, 2004
    2,603
    34
    48
    mechanic
    Hello Melvinmelvin. Yep thats easy. Unplug the gearbox solenoids. Default is 4th(overdrive) without the solenoids working. I do this for testing on the 4 speed box. Pulling it all the way to Low gives you first , Second gives you second and Drive gives overdrive. You loose third as there is only 3 positions.
  7. melvinmelvin
    melvinmelvin Member
    Sep 24, 2012
    248
    2
    18
    Not much
    Bangkok
    wow, thanks,
    wish I had known that before I threw the autobox away
    could actually comfortably run the autobox in a boat then, without the box jumping up and down between the two highest gears
  8. gloverman
    Oct 15, 2004
    2,603
    34
    48
    mechanic
    yes. They are easy to wire up the solenoids too for manual type control so you could have any gear. They suck the power though a bit but it would be an interesting experiment to see how it worked.
  9. melvinmelvin
    melvinmelvin Member
    Sep 24, 2012
    248
    2
    18
    Not much
    Bangkok
    if I buy another 1UZ I will definitely try, this sounds good to me,
    a few horsepowers down the drain in return for overdrive is OK,
    what I would have problem with losing is low end torque
    the 1UZ bellhouse/gearbox is a much better fit for my transom than
    the customary Isuzu/Mazda combination I use now
    the only downside I can spot without thinking too much would be the reverse gear,
    I assume the reverse in the autobox doesn't go high in revs,
    with a 2-bladed prop designed for high speed one need revs in reverse in order to brake rapidly
    (with the Mazda box the 3rd gear (turned) is used for reverse)
  10. gloverman
    Oct 15, 2004
    2,603
    34
    48
    mechanic
    Why would you loose torque with the auto?
  11. melvinmelvin
    melvinmelvin Member
    Sep 24, 2012
    248
    2
    18
    Not much
    Bangkok
    I wouldn't,
    sorry if my usual mistreatment of English is unclear,
    what I tried to say was that I can afford a few hp down, but can not afford Nm down.
  12. Bhogg
    Bhogg New Member
    Feb 5, 2016
    17
    1
    Disability worker
    Ok thanks
    Do you know if the gen 2 ECU’S work in the gen 1? And if so is it just a simple swap?
    Cheers mate
  13. gloverman
    Oct 15, 2004
    2,603
    34
    48
    mechanic
    I'm fitting a gen 2 ecu onto a gen 1 engine atm. Quite straightforward. All the engine sensors are the same except for the afm. I'm swapping on a complete matching ecu and loom and wiring it accordingly. This will give sequential injection (I've checked I've got the correct matching injectors for the ecu too) . The earliest gen 1 trans needs the internal loom swapped whereas the later gen 1 trans you don't use the three pin vss on the tailshaft. My one is running a different trans so I've integrated the separate trans computer into the engine loom along with the 4x4 engagement wiring.
  14. Bhogg
    Bhogg New Member
    Feb 5, 2016
    17
    1
    Disability worker
    Cheers Gloverman
    I’ve got nothing on my tailshaft, so not exactly sure what that means?.
    Just a pity there wasn’t an easier way to make the auto crack a bit harder, So is it worth me trying a latter ecu or how will I tell if I’ll fit and if it will fit what exactly will this achieve?.
  15. American Locomotive
    American Locomotive New Member
    Nov 2, 2015
    22
    1
    Fabricator
    USA
    TransGo sells a shift kit that fits the A340E if you want harder shifts.
