1uz 98 key transponder
Discussion in 'Wiring' started by garage, Jul 30, 2017.
Tags:
  1. garage
    garage New Member
    Nov 29, 2016
    1
    1
    mechanic
    bahrain
    i have 98 1uz fe vvti with the key, ignition ring, key transponder. 5 wires are coming out of the transponder (black, white and blue, white, white and yellow, red) i know that i only need to use 3 and wire it to the ecu but dont know which 3 and where in the ecu
    this is my ecu pinout
    [​IMG]
  2. George_R
    George_R Member
    Sep 13, 2010
    846
    2
    18
    Gender:
    Male
    DSP engineer
    Russia, Moscow
    Home Page:
    Transponder is the chip inside the key
    The ring is called antenna, and small box behind the ring is amplifier
    Properly asked question contains 50% of the answer
